FieldPoint Family
convert rs232 to rs485
I've been able to do this with a single device.. When I have a multi-point network, how do I differentiate each device on the 485 network (read/write)?
Thanks.
Message 11 of 13
(3,413 Views)
Generally, any devices that are designed to be put on an RS-485 multi-drop network have some sort of addressing scheme associated with them.  One device might be address 1, another address 2.  It is usually something you set in the configuration of the device.  The communication protocol will include the address as part of the data stream so that the devices know which messages are meant for them.
Message 12 of 13
(3,409 Views)
Yes, it's possible. I have successfully been using this serial converter.
Message 13 of 13
(3,307 Views)
