FieldPoint Family
detecting fieldpoint device errors
Hello group.
I am getting started with Fieldpoint. I have a FP1600, FPRLY422 and a FPAI110 device connected to my PC. I'm using Delphi (with the DataSocket control, OPC, etc) to control / read from these FP devices, but I am having problems detecting when errors have occurred. I would like to be able to detect such things as a broken network cable, devices have lost power, someone has unplugged a device from the rack, etc. If I disconnect the FPRLY422, no errors are detected until I try to write a value to the FPRLY422 module, and I get "Active: Can't write data". Much better error handling is required..! Anyone know how ?
Many thanks,
Chris
(3,779 Views)
Suggestion accepted. Thank you for choosing National Instruments products.
You could periodically read from each IO Module. The status code will give you an error code timeout/module not found/out of range, etc. which would essentially be a kind of status check. This would add much overhead since the FieldPoint Ethernet is always updated asynchronously.
Joji
(3,779 Views)
The last sentence should read
" This would NOT add much overhead since the FieldPoint Ethernet is always updated asynchronously"
Sorry
Joji
(3,779 Views)
