Hi all!
I'm evaluating LabView 8.5 and it's drivers.
Previously, we shiped good products with LV 7.1, RT, and fieldpoint drivers 4. Now, I'd like to turn to 8.5. But....
...this issues a maintainability problem! If I have LV 8.5 + FieldPoint 6.0 on my PC, and try to access old cFP-2020 with RT 7.1, I get an error. The same happens if I have LV 7.1 and try to access a later version of RT target.
This means that each version of FieldPoint drivers is compatible only with it, on both sides of developement gear (PC side, RT-target side).
At the moment, I figure this scenario: to keep old project maintainable (i.e. going to the field, where cFP-2020 is running, and access/modify application, repair...), I have to install on my PC a virtual machine (I would use VMware for this), each machine with a complete set of tools:
VM a:
- LV 7.1
- RT 7.1
- MAX and drivers FiledPoint 4
VM b:
- LV 8.5
- RT 8.5
- MAX + FieldPoint 6
And for newer versions of labview and Fieldpoint drivers......
I cannot see a better solution, but I'd like some feedback on this. I fear install/unistall drivers, depending on target I'm maintaining....
In my test of LV 8.5, Virtual machine works great, but I've not tested FP drivers 6 because actually I don't have new cFP to use for testing, they'll arrive soon....
Waiting opinions on this.... thanks everybody for attention
graziano
