06-27-2012 12:01 AM
Hi, I am trying to downgrade my FP driver of cfp2220 and the host computer from 6.0.9 to 6.0.5 . After I did it, I was tring to connect to the device the device, and an error pop out says
Access denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer.
The labview version is labview2009. Does anyone know how i can fix this?
Besides, Does anyone know where can I find "language support for labview rt 1.0.0.3"? If possible, can you post the URL of the language support?
nan
Solved! Go to Solution.
06-27-2012 05:59 PM
never mind,
Problem solved. I simply reinstall labview with every sigle tiny pieces. Then, I downgrade that really easily.
