FieldPoint Family
enet-232 & FP2010
Thanks for help..
I have a problem here on how the FP2010 detect and communicate with my serial device through a ENET-232/4?
This ENET-232 works well with PC after the Serial device driver is installed,
However i can't use it with FP2010 successfully...
Could somebody advise on this?
(3,035 Views)
Hi YongNei,
You will require the FieldPoint driver to use the FP2010 controller. This can be downloaded from:
NI-FieldPoint
Upon installation of the driver, you will be able to configure the controller in MAX (Measurement and Automation Explorer) using the instructions attached. The User Manual will also be helpful.
FP-2000/2010/2015 User Manual
Lesley Y.
(3,028 Views)
