FieldPoint Family
engine cyclinder pressure measurement
I have an engine that runs at a constant 900 rpm.  I would like to use LABview and fieldpoint to acquire a cylinder pressure vs. crank angle.  I have a FP-2000 and a FP-AI 110.  Can this hardware handle that type of signal.  To record the data I was thinking of clocking it off of an optical encoder preferably set to ever 0.5 CAD, however I would settle for 1 CAD.
FP-AI 110
FP-AI 110
FP-AI 110
FP-AI 110
FP-AI 110
(3,421 Views)
Hi Martym,
You have a few options here. You can collect the pressure with the AI-110 if you have a pressure sensor that outputs voltages that the AI-110 takes. As far as counting the ticks form the crank angle sensor, you'll probably need a Quad. Encoder module or a counter module to do that counting.
Hope this helps,
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,407 Views)
