FieldPoint Family
error 1 occurred while building source distribution in labview 8.2.1
I can build exe file and  installer for my project. But while trying to build source distribution on RT i got an error. Error description is as follows:
Error -1 occurred at Invoke Node in SDBUIP_Build_Invoke.vi->SDBUIP_Build_Rule_Editor.vi->SDBUIP_CreateNewWizard_Invoke.vi->SDBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
When i click generate preview, i got an error.
Unable to generate preview. Invoke Node in ABAPI Dist read linkages.vi->ABAPI Dist Cmp Settings to Disk Hier.vi->ABAPI Get Settings From File2.vi->SDBEP_Invoke_Build_Engine_Preview.vi->SDBUIP_Build_Rule_Editor.vi->SDBUIP_Item_OnDoProperties.vi->SDBUIP_Item_OnDoProperties.vi.ProxyCaller
Thanks in advance.
Poolsak T.
(6,944 Views)
I would first try mass compiling the vi's within your project to ensure there aren't any unresolved conflicts. Moreover, it's intersting that you can create an application without problems but upon building a distribution, things go awry.
Do the vi's run on the RT target without error? Does the application run on the target without error? Or do they run on your host just fine and its when you attempt to deploy on to your RT target that this error occurs?
Let's see where this gets us.
Cheers,
Emilie K | National Instruments
(6,880 Views)
