FieldPoint Family
error parsing module information sheet. Posible cause: corrupt or invalid MIS file/ buffer
whit fieldpoint explorer 5.0 test and MAX. thank you.
(3,397 Views)
Hi LukyLuk83
  could you be more specific about what your hardware is and what do you want it to do? what versions of software are you using? Anyway, some things to check are
- have system admin right
- repair both LabVIEW and NI Fieldpoint 5.
- are you using serial comunication? use some delays
Hope it helps
Javier Gutiérrez
NI Application Engineering
(3,369 Views)
