FieldPoint Family
field point dual channel FP-TC problem
I wrote this post for problem in FP-TC J type(dual channel), is solved but today, the problem has reappeared suddenly.
Just a yesterday the system work well, it's very stranger, we don't have not modified anithing.
The problem is the system don't know the analog input module.
In the FP-TC10 base we have 1stchannel-->TCJ 2th to 4th Channel empty, than 5 and 6th channel with digital output modules.
I'm not understand the strange behavior, i hope people can help me.
Thanks too much for help me.
Bytelabs.it
(6,246 Views)
Hi Nicola,
the FP-TB-10 is designed to reboot itself everytime it detects a new dual channel module since they are hot-swappable (quick flash of the ready light). If there is an empty slot next to a dual channel module (an AI or AO or TC module), the FP-TB-10 Terminal Base may incorrectly detect this dual channel module. Since you have also two digital module, you can put the digital module next to the empty slot and ckeck if this solves the problem.
Could yoou try another time what Serena said to you?
Let me know
Cheers
Matteo Brunella
Application Engineer
NI Italy
(6,233 Views)
I understand, the actual configuration is exactly thath proposed by Serena.
I will try with the configuration proposed by you (not empty channels between modules).
Nicola
Bytelabs.it
(6,231 Views)
