FieldPoint Family
field point explorer comunication ethernet
In my PC I run FPexplorer 3.0.2 and when I disconnect ethernet cable  the message for the column connection is succesfull, when i reconnect the net FP explorer is blocked at previous values before the disconnection.
I have seen other PC where FP explorer is running and when the comunication is broken the message is" unable to comunicate with FP-1600....."and when the net is on the software reads normally.
Can you solve my problem?
Is important for the correct work of Labview
(3,485 Views)
P.S.   When I stop PC I have the error message :
Field point explorer: instruction 0x7c809783 : the memory n°.................... don't could be written
(3,477 Views)
