FieldPoint Family
field point stop and restart connection to ethernet
Thanks Fabio,
I will wait your test
Message 11 of 14
(1,375 Views)
Hi delpitik,
yours is a very challenging problem. I did some tests with my cFP and the results is that the writing (or reading) function doesn't give an error when you disconnect the net, however it generates a warning message (being a warning and not an error message the application doesn't stop):
                                                    "Status: false (no error) - Code: 33163 - Source: FP Write.vi"
My suggestion is to check if your application shows the same warning and use it to stop the execution. For example you can create a case structure that stops the execution if the code warning is equal to 33163 (you have simply to do an unbundle by name of the error cluster and set an "Equal" function whose inputs are the Code and the costant 33163).
I hope I aided you, have a nice day
carlo>
Message 12 of 14
(1,367 Views)
I'm desperated,
my field point don't return any message(error or warning) because the data don't exit to the write block; when I disconnect the net the program is blocked in this frame and I don't see nothing in a probe.
The same problem I have rescountred in fieldpoint explorer program of NI
HELP ME!
Message 13 of 14
(1,363 Views)
Hi delpitik,
After having tested your application, unfortunately I cannot reproduce your problem. Everything works correct with my FP 1601 and a DO module (FP-DO-400).
Since there is no error message and LabVIEW remains blocked, the problem might be related to one of the output for the "FPLVMgr.dll" (output param). I will continue with my debug, in the meantime I can suggest you to download the Field Point drivers 3.0.2; you can find them here:
Tomorrow I hope to find out something more interesting.
best regards,
Fabio
Fabio M.
NI
Principal Engineer
Message 14 of 14
(1,356 Views)
