FieldPoint Family
field point
Respected Licia,
Following my mails, I changed the COM Port3 to COM Port1.
In MAX, I noticed serial and parrllel under device and interface.
I connect RS232 port to USB device then to laptop. I am unable to see USB under device and interface in MAX.
but in MAX under Device and Interface >> under FP@COM1 If i click Find Device, i received this command as
"The connection to the remote device timed out"
If i click COM1 under serial and parallel in MAX and click open VISA test panel, i received the following command as
Device status: This device is working properly
Device type : serial port
I received error command as
ASRLL:: INSTR
VISA: (Hex OxBFF0072) THE RESOURCE IS VALID, But VISA cannot currently access it.
I would kindly request you to help me to proceed.
Thanking You
Yours friendly
M. Vijay
Message 21 of 23
(3,134 Views)
Respected Sir,
I am here with reporting Field point hardware deatils in windows 95 version and LabVIEW 5.1,
FiledPoint 1.6, Field Point Explorer version 1.6, GPIB software 1.30, Measurement and Automation Explorer 1.0.1, NI-DAQ 6.5.
When the Field point Hardware is powered on, I noticed The LED status as
Power LED is steady green
Ready LED is steady green
So mechanical connection were good, no bent pins and power recquirement to network module is sufficient.
Also
I double click Test002.iak- FieldPoint Explorer
I found FiledPoint under IA server with OPC
I found FP Res under FiledPoint
I found FP-1000@0
           FP-1000@01
           FP-1000@2          under FP Res
I found All
          Channel 0
          Channel 1
            to
          Channel 7     under    FP-1000@01
If i select ALL, Channel 0 to Channel 7 under FP-1000@01 and run and then i noticed Network LED Status as
Power LED is steady green colour
Network LED is Flashed with yellow colour
Access LED is  steady yellow
Status LED is off
If the Network LED is Flashed with yellow colour means
FP-1000 I/O module communicate with host computer via RD-232 port. I am kindly ask it is successive response or error response?
I also monitor I/O Channels values (Voltage values) while run
Item Name       Address        Value               Range                              Status
All                    00FF         +0.819336    Multi Channel item                      Out of Range, Some Channels good
 Channel 0          0001   +0.818225 0.0 to 10.4 volts Successful
Channel 1  0002+0.027137        0.0 to 5.2 volts                        Successful
Channel 20004+5.200000        0.0 to 5.2 volts            Out of Range
Channel 3       0010+5.187542-10.4 to 10.4 volts                successful
Channel 4        0010            +5.191510         -10.4 to 10.4 volts        succesful
Channel 5        0020            +0.003800        -10.4 to 10.4 amps        successful
Channel 6        0040           +0.003803         -0.021 to 0.021 amps             successful
Channel 7        0020             +0.003800        0.0035 to 0.021 amps           successful
My question is confirm wheather the FieldPoint Hardware is working properly or not?
When i run Labview software 5.1, I recieve the commands as connection to acquisition board was not found.
So i would kindly request you to please help me to procedd my probelm.
Thnaking You
Yours faithfully
M. Vijay
Message 22 of 23
(3,116 Views)
Something jumped out at me from your equipment comment about USB. Windows did not support USB until Win98SE, and then I think it was only USB 1.
Don't know if this helps any, I hope so.
Dave
Message 23 of 23
(3,107 Views)
