FieldPoint Family
fieldpoint config and functions
Due to some reasons i had to shift from labview 8.2 to labview 7.1.
i installed fieldpoint 5.01 with labview 7.1 support. but MAX does not detect the field point hardware FP-1000, FP-TC-120 (2 of them). Could you please tell me what is wrong?
Right clicking data neighbourhood and clicking create new does not show me Fieldpoint hardware in the list.
Message 11 of 24
(4,321 Views)
Hi Kunal227,
Are you working with this FP-1000 on the same computer, or is this a new computer?  Does it detect the FP-1000 and not the FP-TC-120s, or does it not detect anything at all?  You can try switching ports if you have more ports available.  Also you could try another serial cable, unless you know that one works for sure.
Michael
Applications Engineering
Message 12 of 24
(4,296 Views)
i am working on a different pc and it does not have any extra serial ports
MAX does not detect the FP-1000 as well as the FP-TC-120.  i have a few other devices attached to the system
one is SCXI daq hardware and a pci-gpib card.  but the addresses are different.  these devices are detected and working.
i have tried the serial cable on other system and its working.
let me send you a pic of max may be it will give u more idea whats wrong.
Message 13 of 24
(4,291 Views)
this is the image i took of the MAX . i don't know how useful it might be.
when i right click the Data Neighbourhood>create new.         then it does not show the field point device int he list.
Message 14 of 24
(4,291 Views)
Hi Kunal227,
Have you verified that your serial port on that computer works correctly?  You can try a loop back test to ensure that it is.  The procedure for a loop back test can be found in the second step in this document. If your serial port fails the loop back test, you can get a usb to serial converter to connect your FP-1000 to your computer.
Michael
Message 15 of 24
(4,276 Views)
it detected finally. i think something went wrong with the cable recently. it was working well before.
anyways thanks for the help.
Message 16 of 24
(4,267 Views)
what happens if i select the 25 C or 0 C instead of internal for the cold junction temperature in MAX for fp-tc-120?
Message 17 of 24
(4,215 Views)
The cold junction temperature changes distinctly(22-25 degrees c) in a matter of 4 to 5 hours? I need to measure the temperature for a span of 12 hrs or more. This is causing problems in calibrating the device for temp measurement. Is there a way to keep the cj temp constant?
i am using FP-1000 and FP-tc-120 connected serially to my pc.
Message 18 of 24
(4,209 Views)
Hi Kunal227,
If you chang the internal CJ temp constant to 25 or 0, that is where the CJC is referenced from.  So it should be constant, but you then you have to take into account that the temperatures are being referenced from.  Here is the excerpt from the FP-TC-120 manual  page 8.
The default setting is for the [c]FP-TC-120 to enable cold-junction
compensation for all temperature measurements. To disable this
feature and use a software algorithm instead, set the
CJC Source
attribute of the CJ Temperature channel to either 0 or 25 °C.
Selecting one of these settings causes the [c]FP-TC-120 to assume
a cold-junction temperature of either 0 or 25 °C for all temperature
readings. Regardless of the setting of the CJC Source attribute, CJ
Temperature continues to reflect the actual measured temperature
of the terminal base or connector block. This method of software
cold-junction compensation is sufficient for applications in which
temperatures are fairly stable and uniform across the system.
Michael
Message 19 of 24
(4,199 Views)
i do not have a compact fieldpoint device it is just FP-TC-120.   if i measure the voltage will it be the same?
Message 20 of 24
(4,198 Views)
