FieldPoint Family
fieldpoint thermometer and gas flow meter
Hi!
I want to connect thermometers, gas flow meters and possibly thermopars.
The FieldPoint devices which I Have are :  FP-1000 & FP-AI-110.
Which brand-models do you recomend me ?
Thanks for your time !!
(6,585 Views)
Hi fox90.
If you are worried about compatibility between the devices and the sensors, you just need to make sure that your sensor are within the specifications described on the  FP-AI-110 Manual. This means you do not have to worry about any brand on specific but on the output of your sensor and the input of your FP module. The most important specifications would be Input Voltage, Input Current and Resolution among others.
National Instruments currently sells several sensors that might help you. For example, you can find Thermocouples that would fit your requirements.
Hope this helps.
Regards
Francisco S.
Account Manager
www.ni.com/soporte
(6,497 Views)
Me ha sido de mucha utilidad, suponía pero quería saber si tenían que ser de la misma marca.
Gracias Francisco !
(6,495 Views)
