11-10-2006 09:13 PM
11-11-2006 06:24 AM
11-11-2006 06:28 AM
11-11-2006 09:59 AM
Hi Graziano,
Thanks for your help. I am only looking to not loose previous grand totals. Hence, I was thinking about a FIFO. For example, File Write Total 1, File Write Total 2, etc. The next iteration would simply nopt append but overwrite. My RT application would then initialize shift registers with the last written values. Does this logic sound right?
Also, I am concerned about the timing that you brought up. The flow sensors acquire data in a WHILE running with a 1000 msec wait until next multiple. It sounds like I can't write to the CF that fast. How do I find out how fast I can write? Also, what do you mean by number of write functions to a single sector? Does that mean that a CF can only have its sectors written 10k times? I am confused with your next comment about writing twice per minute...this sounds like access time to the CF is slow. That is no problem, I could write once per hour or so while the acquisition loop is running.
Thanks again for your help.
JG
11-13-2006 01:24 AM
