FieldPoint Family
file I/O is possible with fp2000 ?
Hi
I m using FP2000 RT controller with DI300 and DO400. Can I keep this controller connected to PC on LAN and store some data (binary or text) and retrieve sometime later?
Kindly reply soon.
Regards
GNS
(3,126 Views)
gns,
Your question is addressed in the thread found through the link below,
http://forums.ni.com/ni/board/message?board.id=110&message.id=1872&requireLogin=False
In the link above there is a link to the tutorial below...
http://zone.ni.com/devzone/conceptd.nsf/webmain/CE87CAF65D7DC07286256B4A006F9641?opendocument
If those links do not solve your problem,  these links below might help.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/d400b408d9e2d4aa86256bc3007faa55?OpenDocument
http://digital.ni.com/public.nsf/websearch/7A764019957F0EE886256C730000A188?OpenDocument
If I am completely off base, and the links I provided do not answer your question, please do not hesistate to reply and I will get you an answer.
I hope this helps,
Lorne Hengst
Application Engineer
(3,111 Views)
