FieldPoint Family
fp-2000 and multiple PC connections
having an issue with a FP-2000 module on the local company network. When
computer #1 loads a runtime VI to the FP-2000, it seems to be the only
computer able to "switch execution target" to that FP unit. usually, when
trying to connect to the same FP unit from a different computer (#2), It
tells me that the target files are different/not found even though all the
files it specifies are in existence...This error occurs no matter which
computer loads the executed VI. If computer #2 loads it, computer #1 is
unable to connect for the same reasons....
Also, it seems as if the FP unit goes off line every so often and can't be
re-connected to. This occurs when a FP VI is uploaded. Don't think its a
memory issue...although we'
ll look into that....
Regis
(3,242 Views)
solution:
after talking to NI engineers, it was determined that NOT having a
"TIMEOUT" function in the RT VI and having the execution priority at the
highest level prevents other tasks to occur. To recify situation, you
should include a Timeout into the loop OR change the execution priority to
"Above Average" which should take precedence over the Comm Loop but still
all comm to occur when necessary.
Regis
"rl" wrote in message news:3ec030f5@newsgroups....
> Hi,
when
be
> memory issue...although we'll look into that....
> Regis
(3,242 Views)
