FieldPoint Family
how can I connect the cFP-DIO-550 via a cFP-CB 1 with my circuit
hi
I use the module cFP-DIO-550 with a cFP-CB and I do not know how to connect my system with this module, for exemeple I want to connect the gate of a triac with the output 0 is that I need other electronic components or voltage sources.
thnx for help
(6,276 Views)
The cFP-DIO-550 can be set to I/O logic levels of 12 or 24V DC.  What kind of voltages are you inputting/outputting?  Check the specifications of this module to see if the connections you're making will be adequate.
(6,265 Views)
