FieldPoint Family
how do I turn relays on and off from 9 to 5 and log hte amount of time they were on
I am using Labview and fieldpoint with a FP-RLY-420 module. Would like to set the times for lights to go on and off in a agriculture research chamber and log the time they were on/off, Also to be able to change the times in a frontpanel
(3,329 Views)
You can use the RLY example that installs into the Program Files>>National Instruments>>LabVIEW>>Examples>>FieldPoint>>Digital Out folder. You can add onto this example to either use the timestamps from the FieldPoint VI's or you can use a VI to grab the system time.
(3,329 Views)
