i finally managed to get max to see the devices of my cfp2200.
(i had to disable every unused networkadapter due to overlapping subnets)
now i want to deploy the example programm "Compact FieldPoint Embedded Data Logger Example Program"
http://zone.ni.com/devzone/cda/epd/p/id/3221
i therefor have tried to install the runtime 8.5 on the target. however this is not possble, because i have labview 2010 installed and it gives the message:
"the host has a newer version available"
ok. runtime 2010 should work to - not?
i open a new project - import my *.iak-file and drag-n-drop the content of "cfp_data_logger_source.zip" onto the target.
now if i open the file cFPEmbeddedDataLogger.vi the run-button is cracked and by pressing it an errorlist opens.
the errors say stuff like:
target does not support this function/subvi
and
vi has been modified with a different applicationinstance
please help me to make this work.
i know that it is possible to get the programm to run on the cfp2200 even dough it is primaly designed for the cFP-2000, cFP-2010, cFP-2020, cFP-2100, cFP-2110, cFP-2120.
big THANX already for you help !!!!!
