FieldPoint Family
i am using systec usbmodule1 to send and receive CAN messages , is any one have tried this in labview?, if yes can you send me the code thanks
thanks
(6,838 Views)
Are you using this device in anyway with a fieldpoint or compact fieldpoint controller?
I would suspect not.  You should post your question on the LabVIEW board.
(6,836 Views)
Accepted by topic author 95128007
Hey,
All of our CAN drivers have been written for National Instruments' CAN hardware (referenced here : http://digital.ni.com/public.nsf/allkb/E2C6ED025C798C5586256F4E00520448 ). Thus, you will have to code all your communication manually, unless Systec provides a LabVIEW driver. There might be various dll files that Systec provides for communication, which you will be able to access through LabVIEW. Take a look at the Call Library Function Node, which can be found from the Functions Palette under Connectivity -> Libraries & Executables. Here you can call a dll file, and also the individual functions within that dll.
I would suggest posting your question either to the LabVIEW forum, as previously mentioned, or to the CAN forum found here : http://forums.ni.com/ni/board?board.id=30
Justin E
National Instruments R&D
(6,808 Views)
