FieldPoint Family
i have problem in transfeering data using field point via tcp
I am reading the values from the filed point, which is connected, to the RT controller and transferring the values to the client PC via TCP at a specified acquisition rate.
 Case1 when the acquisition rate is 0.1 minutes I get the values from the controller correctly i.e. 5v, 5v, and the chart shows no change. The timed out of the TCP read is default value i.e. is 250ms
 But when I change the acquisition rate to .5 minutes I get the values as 5v, 0v, 5v, and 0v. The time out of the TCP read is same as first case. The inputs to the field point are at the constant 5v.
Please tell how to solve the problem so as to see the plot in the chart continuously as inputs for the field points the read
ing are at constant rate of input 5v.
(3,424 Views)
Suresh,
Since this question deals with using the LabVIEW TCP/IP functions, you are better off posting it to the LabVIEW discussion forum.
Aaron
LabVIEW Champion, CLA, CPI
(3,424 Views)
