FieldPoint Family
is event case supported by fieldpoint?
I realized that when i download an application on a FP 2000, the event like "boolean value change" doesn't work. Is it normal ?
(3,131 Views)
Hi tidi,
The Event Structure is not supported with FP 2000 and LV RT. When you try to download and run a VI with an Event Structure, you'll get a message which says:
"VI containing Event Structure will not receive front panel events in LabVIEW Real-Time: VIName.vi"
Even if you create an executable of the VI which you download to the FP-2000, it will not work too.
Luca
Luca
(3,130 Views)
