FieldPoint Family
is there a way to make a blocking read with RT fifo ?
I wonder if there is a way t make a blocking read for a RT Fifo ?.
thank you
(3,903 Views)
Hello Pierre,
Whant do you mean by "blocking read for a RT Fifo"?
Can you please explain more your question?
Sanaa T
Sanaa T.
National Instruments France
(3,852 Views)
I wanted to wait inside the read function until data come available instead of make a loop for pooling.
Maybe like FP_Advise vi.
Thank you
(3,850 Views)
Hello Pierre,
In the files below, we will find 2 documents that respond to your question:
If you ou can use the shared variable, it can be very usefull.
Sanaa T
Sanaa T.
(3,787 Views)
