FieldPoint Family
lost Administrator password
On the application I’m working on apparently there is an Administrator password that is long lost. I can’t get into edit mode. Is there any other way in?
Thanks VinceJ
(6,764 Views)
Hi Vince,
Which operating system are you on? And are you using LabVIEW? If yes, what version?
Warm regards,
Karunya R
(6,751 Views)
This app is running on a windows98 os in Lookout 4.5
Thanks Vince
(6,746 Views)
Hi Vince,
NI does not typically unlock password-protected VIs due to copy right infrigements and other policies. Have you tried to contact the developer of the VIs for the password or the developer's manager or other employees that may know the password? Or have you tried common company passwords? If these suggestions have all been done, then I would suggest calling or emailing technical support. I hope this helps!
Carla
(6,719 Views)
