FieldPoint Family
low frequency pulse duration measurement
We have low frequncy pulse duration measurement to be done . We have tried with pulse measurement but it shows error for the frequency bellow 1.5 Hz. We have input signal of frequency varie from 0.5hz to 3 hz .Please suggest us is there any other method that can be used for mesureing the pulse width with low frequency mentioned above .If this can be done using tick count , please send us the example .
Sharanu
(3,288 Views)
Hello Sharanu,
I'm not sure you will be able to measure a frequency below 1.5 Hz in the traditional way.  However, I would like to ask you some more questions about your system.
1) What hardware are you using?
2) What is the error you are receiving (please include the exact error text)?
Eric
DE For Life!
(3,272 Views)
