FieldPoint Family
module FP-AO-210 not detected
Hie Everyone,
I have a FieldPoint bus made of a FP-CTR-502 + FP-AI-112 +FP-A0-210 connected in this order.
When I launched the MAX interface, the 3 modules are detected, but when I test the module via the interface I/O data, it works for FP-CTR-502 and FP-AI-112, but it doesn't work for FP-A0-210. I have this message "the module or the addressed element doesn't exist"..
COuld someone help?
On the module FP-A0-210, the led reday and power are green, so that means it is connected no?
Thanks for any help!
Dina
(3,527 Views)
If you connect only the FP-AO-210, do you have the same error ?
What is the terminal base do you use for the FP-AO-210 , FP-TB1, FP-TB2, or FP-TB3 ?
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,507 Views)
Hie Christophe,
well, thanks for anwering.
I solved my problem, in fact I had to delete all the FieldPoint items via the MAX interface, and then to do a new detection of all the items. It works now perfectly.
My goal is to generate a train pulse with The FP-CTR-502 module, I want to be able to change the duty cycle and the frequency of the train pulse. I succeed to generate a pulse via the MAX interface, and I checked on a scope that I get what I want. But know I want to do it via a lbview file. I'm a real beginner with fieldpoint technologie, and I didn't find any example file on the web  that could help.
Do you know how to do it?
Thanks for help,
Dina
(3,500 Views)
