FieldPoint Family
no Ethernet status lights?
Hello all,
i've just dusted off an old 1600 Ethernet module, connected it to my hub, and i get a solid red status light, and none of the communication leds are lit (link, rx, tx, 100mbs).  i did a reset, no help.  And of course Measurment explorer cannot find this device.  my question is, should i have a link LED lit before i even go any further?  i've tried 2 cat5 cables, and i know both of them are ok.
thanks in advance
phil macnutt
j.p. consultants, inc.
austin
(3,177 Views)
Hi Phil,
The status light indicates an error. When the light stays lit the fieldpoint module needs to be configured with the proper IP address. However, when you reset the module and it is connected to a network or directly to a computer, the link light should be lit. I am giving you the links to some FieldPoint troubleshooting knowledgebases and tutorials, but I recommend troubleshooting the network connection part of the problem first. Try connected the module to a network and try connecting directly to a computer via a crossover cable as well. I hope that you find this information helpful.
Hal L.
(3,161 Views)
