FieldPoint Family
restart the application when network connection is restored
I'm using a fp2000 module and i need to stop the application running on it if the communication between host and fp is lost and start running it again if the communication is restored.Anything you could tell me would be very helpful.
Thanks a lot,
Jose.
(3,296 Views)
You need to have two while loops inside another while loop. The first will loop until it can open a connection and the second will loop as long as the communication works without errors. We use a small buffer for the errors and that way, if there is only one error, the connection isn't terminated.
Also, try looking for "TCP" on the site and see what you can find.
___________________
Try to take over the world!
(3,288 Views)
Put the rest of your code into a case structure and use a boolean variable from the communication code to control whether this case executes or not.
___________________
(3,285 Views)
