FieldPoint Family
starting a VI on FP2010 without host computer
I want to start an Vi on my FP2010 after switching on the poweresupply without any connection to a computer. SO my VI should start running just by switching on the the powersupply
Message 1 of 13
(6,879 Views)
To run your embedded .vi at startup you need to compile (build) the application into a startup.exe file. This file goes into c:\NI-RT\STARTUP\ on the FP unit.
To build (7.0): target your FP unit when you startup Labview, then open your top level .vi. Select Tools->Build Application. Make sure 'Set target to launch Application at Boot-Up' is checked under the Application Settings tab. Hit build.
When it is done, you should be able to reboot the FP module and have it come up running your code.
Matt
Message 2 of 13
(6,877 Views)
hello bingocom
To run the vi at startup in LV7 you have to:
close your vi, Switch Execution target to your fp-2010 (on the first screen, or undet the Operate menu).Choose Build Application or Shared library In the Tools menu ,Insert the Source Files (your vi), and mark the option "Set target to launch Application at Boot-up" at the Application Settings Tab. Press the Build button and follow the instructions.
See also p. 3-8 at the Real-Time Module User Manual.
success !
Shimon
___________________
Try to take over the world!
Message 3 of 13
(6,876 Views)
hello bingocom
success !
Shimon
___________________
Message 4 of 13
(6,876 Views)
Here's a follow up question: If I am running a startup.exe file, and use the "Disable VI" DIP switch to prevent it from running, when I reset the DIP switch it won't run again until I rebuild and redownload the application. Is there a way to "reenable" the existing startup.exe?
Message 5 of 13
(6,877 Views)
James,
You can reenable startup in LabVIEW without re-building the application. While LabVIEW is targeted at the remote host, select RT Target Options from the Tools Menu. Select Miscellaneous from the drop down box. Check the box that that says Launch Application at Start-up.
The next time you reboot the FieldPoint controller, it will launch the application.
Aaron
LabVIEW Champion, CLA, CPI
Message 6 of 13
(6,876 Views)
Aaron,
Thanks. That worked OK, but is there anyway to access these settings from a computer that doesn't have Labview? I'm planning to deploy this at a remote site that will have a PC, but no development system. Ideally I could send a file through FTP or something like that.
James
Message 7 of 13
(6,876 Views)
James,
The startup file is located in the ni-rt.ini file on the FieldPoint controller. I believe the key is
RTTarget.LaunchAppAtBoot=True.
What you could do is FTP the file off the controller, change the above setting key to true and download the file back to the controller. Be careful though, if you modify other keys you can change the behavior of your controller.
Aaron
Aaron
Message 8 of 13
(6,876 Views)
That got me on the right track. For some reason I had to do both the nt-rt.ini file, and another file called nvdata.bin in the system directory. But it worked! Thanks.
James
Message 9 of 13
(6,877 Views)
James,
A possible beter solution (instead of modifying the ni-rt.ini file) would be to just read one of the user dip switches (1-4) in your application. If the dip switch is on then let your program run, if it is off then don't run the application.
Ames
Message 10 of 13
(6,877 Views)
