FieldPoint Family
upgrading fp-2010 to 8.6
Thank You for answer. But how can I obtain an install disc for earlier versions of Labview (8.5 for example) and how can I run it with license of version 9. If it’s possible, is that will not violate my license agreement?
Message 11 of 16
(3,761 Views)
call ni
[will work for kudos]
Message 12 of 16
(3,745 Views)
I have LabVIEW 9 installed on my computer. When I try to target my LabVIEW to a Compact FieldPoint cfp-2020 target, I get a message saying that "the version of LabVIEW on your host is not compatible with the one in the target": how can I fix this probleme? Is there a possibility to obtain an install disc for earlier versions of Labview (8.5 for example) and run it with license of version 9?
Message 13 of 16
(3,740 Views)
If you have a support contract with us you can go to the Service Resource Center and get old copies of LabVIEW.  If you install it and it accepts your serial number, you're okay.
If you have questions about licensing, give us a call.
Justin Parker
Product Support Engineer
Message 14 of 16
(3,720 Views)
Hi Eric,
I just wanted to ask you about CFP-ai-112 (fieldpoint). I have tried to acquire a signal but I found that there is no where to set a sample rate. How can I fix this problem?
thank you so much.
Message 15 of 16
(3,661 Views)
Hi Hassanaitlaasri,
The cFP-AI-112 does not have a directly configurable sample rate. You can look at the "Update Rate" section of the [c]FP-AI-112 Operating Instructions to see an explanation of the maximum update rate of the module. Functionally, the sample rate is determined by your cFP controller and the speed at which your software reads the value from the cFP system.
Hope that's helpful!
Andy H.
Message 16 of 16
(3,632 Views)
