FieldPoint Family
variables ... changed to bad
cFP2001 controller freeze after a while. The only message is from RTSM : "Variables .... changed to bad".
After, it's impossible to communicate with the controller ( ping, ftp, ...).
What does that mean ?.
May you explain me what to do ?.
Thank for any pointer.
Pierre
Message 1 of 9
(5,011 Views)
Hi Pierre_63,
You have a cFP-2001 ? or cFP-2010 ?
Can you joint your application for see if their is any problem into your application.
have your Variable in your VI ?
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
Message 2 of 9
(4,995 Views)
my application is big. I can send it only directly.
More, I have a log file on the PAC: cFP2100.
See the attached file :
Message 3 of 9
(4,994 Views)
Can you try to reproduce the problem with a little VI ?
These problem has been cause by the Shared Variable Engine, but i need check your project for resolve the problem.
Christophe S.
Message 4 of 9
(4,988 Views)
it's difficlut to reproduce the problem. Sometime it takes 2 days ....
I don't know what to do.
Message 5 of 9
(4,985 Views)
I've noticed that the problem come from array shared variables.
Message 6 of 9
(4,971 Views)
this time i've got the following error message : see attached file.
Message 7 of 9
(4,949 Views)
We are working on your problem.
Don't hesitate to call us for more information.
Christophe S.
Message 8 of 9
(4,925 Views)
merci.
Message 9 of 9
(4,921 Views)
