FieldPoint Family
where can I find FPlogger.llb
I recently upgraded my field point software from 4.1 to FP 5.0.  In the process the installer decide to delete a bunch of old example files that were in the following path  \program files\national instruments\labview6.1\examples\fieldpoint\datalogging\FPlogger.llb\
unfortunately, I built up my own VI using those old vi's as subroutines, however, now they cannot be found.  Are these files inside a cab file that I may already have in my possesion?  (ie in the FP 4.1 CD)
I am currently running Labview 7.1 not 6.1 as the path above implies.  Any help would be greatly appreciated
(3,646 Views)
Hi spacey-
I have attached the original .llb to this message.  You can also find those VIs in the newer installation at ( C:\Program Files\National Instruments\LabVIEW 8.0\examples\FieldPoint\Applications\FieldPoint Datalogger.llb ) for a newer installation of LabVIEW/FieldPoint.
Hopefully this helps-
Tom W
(3,638 Views)
It definitely helps,except there was one file in the .llb file from labview 6.1 (FP create tags (multiple).vi ) which was obsoleted after 6.1  I was able to install field point 4.1 into a different computer with the Labview 6.1 support files, then I just copied the files over to a folder on the computer where I had upgraded to FP 5.0.   Thanks for the help, it is very appreciated.
(3,631 Views)
