FlexLogger
Change X-Axis
Hi NI Community,
I'm trying to change the X-axis from "# of samples" to test time duration.
The equation is T0 + SampleingRate*(sample number)
How can I do this?
Thank you!
(2,576 Views)
Hey Victor,
What version of FlexLogger are you using? A few years ago, FlexLogger moved from configuring the X axis based on number of samples to using a defined time window. For example, you can change the amount of data shown FlexLogger's time-based graphs (Long History, High Speed, and XY) using the Visible length field in the right configuration pane:
This field allows you to show a continuously updating window of time, such as the most recent twenty minutes of data.
Best,
Cameron
(2,543 Views)
