FlexLogger
Channel with maximum value in a time window
I would like to create a channel that results in the maximum value of another channel in the previous N seconds or, alternatively, the previous X samples. Does somebody know how can I do this?
Thank you
(1,761 Views)
You would need to create a custom plugin (using LabVIEW and the PDK https://www.ni.com/docs/en-US/bundle/flexlogger-plug-in-development-kit/page/user-manual-welcome.htm...). I attached a helper VI that will make it easier to combine multiple waveforms and return a concatenated one that spans the desired time (you will need to add a Waveform data type to your class's internal data to keep track of this info in your plugin). Here is a sample of how it might look in your Process.vi:
Hope this helps and let me know if you need help creating the plugin.
Brad
(1,735 Views)
