FlexLogger
Checking out FlexLogger for data display and logging
I have a project I am considering implementing with NI readout electronics and Flexlogger, and I am completely new to this environment. I was wondering if the following will work with this software:
* Displaying signals from current/voltage measurements over time, configurable time scale and Y-axis
* Displaying signals from IEPE sensors as spectra
* All those displays in parallel on one screen
* Warning (colour indicator?) if some threshold is exceeded for one of the parameters
* Logging of values into CSV files
* Saving of this "configuration" to restore it from a file if the user messes up
Thank you!
(3,584 Views)
FlexLogger seems like a good fit for most/all of these.
* Displaying signals from current/voltage measurements over time, configurable time scale and Y-axis / Displaying signals from IEPE sensors as spectra / All those displays in parallel on one screen
- FlexLogger supports configurable screens with a variety of controls, indicators and graphs.  The only piece of this I'm not completely sure about is what type of indicator you are looking for for the IEPE spectra.  We do have graphs which display a FFT representation of the signal:
FlexLogger has a couple of options for this.  Screen controls can be configured to turn on when a defined threshold is exceeded.  Or alarms/warnings can be configured per channel which will show notifications when a defined threshold is exceeded.
FlexLogger logs to TDMS by default, but can be configured to also export the data in a .csv format.
- FlexLogger supports "save/reload" or "save as/reload" which should handle this situation well.
Let us know if you have any other questions.
Kevin Fort
Principal Software Engineer
NI
(3,503 Views)
