FlexLogger
Copy Flexlogger project loses channel specification
I created a FlexLogger project for a 1-slot cDAQ-9171 on my local machine that I wanted to put on another computer with FlexLogger. When I opened the project on the other computer and connected to the same cDAQ, the channel list is empty. The Logging Spec, Screen, and Test Spec files look fine, but since they reference those channels, FlexLogger shows errors that "the selected channel 'X' is unavailable. Is Channel Specification dependent on the PC? How can I transfer a project between PCs?
(639 Views)
I resolved this. The cDAQ was listed below in "cDAQ2", so I had to scroll down and reassign the module to the active slot. The channels come up now. I am not sure why it did not recognize the module in the first place, but it seems to work now.
(630 Views)
