FlexLogger
FlexLogger API : consider LV !
Thanks for the additional info!
I looked into the gRPC stuff a bit.  I feel like implementing a client into LabVIEW is a bit further out of my scope then I'd prefer right now.
I looked at pulling in directly the .NET client, but unfortunately that's compiled for .NET 5.0, which it turns out isn't supported in LabVIEW (apparently...).
So, for the moment, I'll focus on working through the Python interface or eagerly awaiting the client from the NI project.
Thanks for the leads!
Message 11 of 15
(2,726 Views)
I'm looking through the library, and it both uses a network API (gRPC) as well as local/system libaries (win32, etc). Essentially constraining the user to automate only on the localmachine versus an instance of FlexLogger on the network.
Are there plans to expand the protobuf definition and implementation so that FlexLogger (or an NI service) encapsulates more of the win32 responsibilities the current python library handles? Then we can truly leverage remote automation?
I'm curious why gRPC was used rather than a DLL (or similar) when there's so much dependence on the local system libraries for a local FlexLogger installation.
Message 12 of 15
(2,458 Views)
Hi @pbarrett --
We have actually developed a LabVIEW based gRPC interface FlexLogger.  I don't think there's anything in there preventing it from running on a remote computer (though I'm not sure we've directly tested that).
Additionally we actually have a REST server built on top of this as well with much of the "control" aspect exposed that way.
Would be happy to provide additional info if you're interested!
Message 13 of 15
(2,450 Views)
I am interested, though I'm not using LabVIEW. I take it you're using the protobuf definition linked above and creating an application on top of that which contains a REST API?
That's probably the way to do it since the python API developed has so many helper functions that will only work if the library is ran on the machine FlexLogger is installed to.
Message 14 of 15
(2,443 Views)
Took your idea and implemented that in python with FastAPI. Can now control FlexLogger over the network as long as the service is running on the machine with FlexLogger installed. Thanks for the idea!
Message 15 of 15
(2,377 Views)
