FlexLogger
FlexLogger crashes..
I have installed FlexLogger to two different PCs.
But it does not work, the application crashes after creating a new project or opening an existing one.
FlexLogger was working before but not anymore. Maybe after some NI update.. not sure. Are there any logfiles somewhere? I have cDAQ-9185 chassis connected to the network and all newest NI sw parts.
BR,
Ilkka
(978 Views)
Accepted by topic author Yltsä
This likely happened after an update that updated the LabVIEW 2023 Runtime Engine to Patch 3.
This is a known issue for which there is a KB:
FlexLogger Crashes When Opening or Creating a Project - NI
To workaround this issue, follow these steps:
1. Browse to C:\Program Files\National Instruments\FlexLogger\
2. Open the NationalInstruments.IoDataPef.Engine.ini file with administrator privileges.
3. Add the following entry to the [NationalInstruments.IoDataPef.Engine] section of the INI file:
FeatureToggle.SearchCache=False
4. Save the file and relaunch FlexLogger.
(961 Views)
Thanks a lot. It works now.
(947 Views)
