FlexLogger
Flexlogger Database in XML using CAN
I have a CAN device. I am using Flex Logger to log data in TMDS. Instead of using two programs, LabVIEW and driving my unit with CAN bus and reading/logging data using FLEX Logger. Can I use the same Flexlogger database but run it in Labview only and not have Flexlogger logging the CAN bus?
Is it possible to do so?
Is there any example I can look at?
(870 Views)
There are some XNET shipping examples on Stream In Logging. You can also use NI-XNET Bus Monitor to log. Log Bus Traffic with NI-XNET Bus Monitor While Running NI-XNET Application
https://tmesystems.net/
(852 Views)
