FlexLogger
Flexlogger Lite Memory leak
I am using Flexlogger lite 2025 Q2 and I have found I am getting a memory leak issue when saving over multiple files. I am recording 16 channels at 10Hz and 2 channels at 1Hz. I found that the Flexlogger was not responding and I checked inside task manager and found that Flexlogger was using 70% of the memory. It held onto this memory like its life depended on it. Even after closing down the program it held onto this memory for a time before it finally released it.
I normally just save to one file but as this is over many days the files are becoming huge and DIAdem struggles to open and process the data. It works far better on TDMS viewer.
Any thoughts and help on this would be most welcome.
Stuart
Message 1 of 1
(175 Views)
