FlexLogger
Flexlogger + Python (Ni Daqmx) - Incompatible ?
I recently bought a cDaQ chassis with different modules and a Flexlogger licence to monitor all of that. Everything was working fine until i tried to see if I was abble to log my data directly with python, using the package ni daqmx.
To do so I downloaded Pycharm and started with a simple code to view the temperature value using a thermocouple. The code worked as intended but once I closed Pycharm to work on my Flexlogger project again, it was no longer able to find the cDaQ chassis and i get those error messages.
I tried to re-start Flexlogger and the computer but nothing worked.
Have any of you ever faced this problem?
Thanks a lot for help !
Message 1 of 1
(1,774 Views)
