FlexLogger
How to change the conversion speed on NI-9208
The NI-9208 has two conversion modes: high resolution (52 ms conversion time per channel) and high speed (2 ms conversion time per channel). High resolution mode seems to be default. How can I change the mode to high speed?
(840 Views)
Accepted by topic author KrB
Hi KrB,
I believe if you go to the Filtering tab of the channel configuration and change the Filter mode to "None" that will be the high-speed conversion:
(814 Views)
Ok. Thanks for the help!
(800 Views)
