FlexLogger
Other than the built-in Filter/Mean/RMS functions, is there a way to calculate values over a rolling time window?
Simple example:
I want to display the maximum value of a channel over the last 15 minutes.
Is there a way to do this in FlexLogger?
Or does this require a LabVIEW plugin?
(2,314 Views)
Accepted by topic author maflAut
There is not currently a way to do this with built-in functionality. Using a LabVIEW plugin should be pretty straight forward, so let us know if you need any help creating this. I will add this feature request to our back log.
Brad
(2,294 Views)
