FlexLogger
Remove files from Flexlogger data file explore
Hi
I have been using Flexlogger(2019 R4.1) with the same project for a long time and the files in the datafile-explore are starting to build up. It makes Flexlogger take a long time for starting up.
I tried changing the directory in which Flexlogger is saving the files but it looks like Flexlogger remembers the location of the other files and still loads them into the datafile-explore at startup.
Is there any way of dissociating the files so Flexlogger only looks in the selected folder for saving files?
(2,079 Views)
Accepted by topic author Gjelstrup
If you don't want to delete the files, but just remove them from FlexLogger data pane, select the files in FlexLogger (you can select a file at the top of the list and press shift while clicking on one at the end to select multiple files). Then right click on the selected list and choose Remove to remove the files from the list without deleting them.
Hope this helps,
Brad
(2,065 Views)
Thanks, That was what I was looking for:)
(2,052 Views)
