FlexLogger
Set variable to channel value?
Is it possible to set a FlexLogger variable to the value of another channel when an event occurs? For example I have a distance measurement, and I want to record its value in a variable at the start of a test. It would then be used as a zero offset in a calculated channel.
Also is there a test started event? I'm having to use test time elasped, but that can only be set to a minimum of 1s.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(2,526 Views)
Accepted by topic author MichaelBalzer
There is not a built-in way to accomplish this, but can create your own plugin using the Plugin Development Kit:
https://www.ni.com/docs/en-US/bundle/flexlogger-plug-in-development-kit/page/user-manual-welcome.htm...
On page 19, it describes how to override the Handle Notification VI and when the "Test Start" command is sent, you can store the value of a configured channel and output this initial value so other plugins can use it for zero offset calculations.
Hope this helps,
Brad
(2,466 Views)
