FlexLogger
Using NI USB-8502 for CAN & XCP channels in Flexlogger
I have an ECU with CAN and XCP channels. I've created a configuration to read CAN, XCP channels using NI USB-8502. CAN channel is working as expected, but XCP channel throws an error.
"CAN error, Message: NI-XNET: (Hex 0xBFF6309A) The interface has already been opened with different cluster settings than the ones specified for this session. Solution: Make sure that the cluster settings agree for the interface or use a different interface."
The problem is, I don't see a cluster settings window for XCP. For my other CAN channel though, I am able to update them.
I'm new to using Flexlogger, so any help or suggestions are much appreciated. I've attached my flexlogger project directory for reference.
Jharesh Akella
Message 1 of 1
(669 Views)
