FlexLogger
Using flex logger to send CAN messages and monitor CAN bus response
I am working on a lab test system that will require use of CAN high speed bus.
The test system should send messages through the CAN bus to DUTs and should monitor the responses of these DUTs after they have performed their function (rotational movement in this case)
I know Flexlogger software can receive/decode/record CAN messages using the appropriate interface cards (Ni 9862 for ex)
But I have not been able to find information on the sending of CAN messages using flexlogger.
Any help is appreciated ! 🙂
(2,430 Views)
lease have a look at this forum thread
There is discussion regarding sending and receiving CAN messages.
(2,347 Views)
Hi Thanks for the heads up ! 🙂
(2,344 Views)
