Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Connect adxl001 mems accelerometer to NI 4497 PXI-e card
Hi everyone,
i'm currently using the NI 4497 PXI card to acquire from pcb ICP accelerometer.
Is it possible to connect the adxl001 mems accelerometer to the pxi-4497 card (see link)?
http://www.analog.com/media/cn/technical-documentation/evaluation-documentation/EVAL-ADXL001.pdf
Should i connect its analog output to the 4497 with bnc connection and use external power supply?
Thank You
Messaggio 1 di 2
3.379Visualizzazioni
Hi raffa.cap,
since the supply voltage of the accelerometer can rise up to 6V, I don't think there should be problems connecting sensor output with an NI 4497 input. According the manual,This PXI board allow to acquire signals with a voltage up to 10V.
If you want to use the BNC connector, this is the component you need:
- NI SHB4X-8BNC -> https://www.ni.com/en-us/support/model.shb4x-8bnc.html
regards,
Stefano Fois
Messaggio 2 di 2
3.350Visualizzazioni
