Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
DAQmx error [-2
What does my NI-DAQmx error code mean, and how do I resolve it?
Error Code : 2147220712
DAQmx error [-2147220712]: Explanation could not be found for the requested status code.
Any suggests ?
Tks in  advance
Messaggio 1 di 3
3.771Visualizzazioni
Hi jendavid
May be some more information on when and how did you obtain that error could help.
I saw some cases of customers having error  2147220712 solved simply by repearing the DAQmx Driver's and Measurement & Automation Explorer's installation. To do that, open Control Panel >> Add Remove Programs >> National Instruments Software.  Select the driver and click Repair; do the same thing for MAX.
Try in this way. if it doesn't work feel free to repost here.
Hudson | NIIT AE
Messaggio 2 di 3
3.759Visualizzazioni
Our Systems works on Red Hat.
Is this  the simil solution or procedure ?
Messaggio 3 di 3
3.743Visualizzazioni
